I have almost finished machining the bullwheel shaft out of the Holden axle; to replace the damaged one off my Viceroy shaper. What it needs before I can progress further with the final machining is a spigot welded? on the end to locate the bullwheel. I have been told that the axle is EN ? and is in the order of 60 ton tensile.
My experience with welding is limited to some fabrication of mild steel. So, can anyone offer any advice as to what method/rod that I should use here.
I would value any input from the good members of this board with experience in these matters, thanks guys.
cheers, Ken
[This message has been edited by speedy (edited 07-22-2005).]
cheers, Ken
