Fire Extinguishers For The Shop
I’m wondering if a CO2 fire extinguisher would be appropriate for a small shop fire. I’m talking about a small fire that has broken out that hasn’t gotten to bad yet. A fire where you have decided it isn’t that bad and you want to leave the ten-pound ABC dry chemical extinguisher in the corner on it’s hanger for now. With a dry chemical fire extinguisher the powder goes everywhere and gets into everything. With a CO2 fire extinguisher you knock down the fire and there is nothing to clean up.
The CO2 extinguishers are about three time as expensive as a dry chemical but I figure cutting loose just once with a dry chemical in the shop will off set the increased cost of the CO2.
The replacement for Halon is Halotron but that extinguisher agent is way too expensive.
But before I spend the money for a CO2 extinguisher I wanted to get some feed back from those who might know something on the subject.
Thank you
Thank you
