A guy brought me an axle from a full floater, wide 9 oval track car. He needed the middle of the shaft built up about .075 so the mid tube seal wouldn't leak. He wanted me to spray weld it but I refused (very pricey axle). I built it up with J-B weld and machined it down. It needs another coat and final turning/polishing. All this is for is the three lip seal so oil won't get slung out onto the brake on the passenger side as it turns. Do you think this will work? Thanks!
Russ
Russ
