How do you calculate the proper depth of NPT when you are tapping? Do you count the number of turns or go for a certain depth? I am tapping 1/8-27 NPT in 304 stainless.
Joe,the basic rule is 5 complete turns forms the maximum effective seal surface of any NPT thread.Thats what I was taught,I also have a hydraulics formula book and chart that gives thread engagement for various pressures.
Most of the time I have found on standard length NPT taps(not dryseal)four threads from the top is about right.
Thanks for the responses so far. I have been cutting 10 to 10-1/2 turns and then I have to relieve the top thread. Like you do Joel. This seems to be the right depth but I have broken several taps when I tap by hand getting to that depth. I have tried several different taps from different manufacturers, all high quality taps not foreign made. I am going to build a jig a try using a Tapmatic and see what it does. Have some taps that are long enough to fit the Tapmatic standard taps are to short. Have been using Tapmagic as a tapping fluid and have some Castrol MoliDee, think that is the name,that I will try.
I may be getting the stainless too hot and causing it to harden. Am going to uses a different coolent and see what happens.
Pipe threads are tapered, and for larger sizes, it is a good idea to use a tapered reamer to size the hole before tapping. I don't know if one is available for 1/8".
Stainless may need a size or two larger tap drill to prevent breakage.
[This message has been edited by JCHannum (edited 07-24-2005).]
<font face="Verdana, Arial" size="2">Originally posted by WJHartson: Darin, when you say 4 threads from the top are you talking about the tap?
I am tapping 1/8 NPT and using an R size drill. I have also used and 11/32" drill but it seems to be to big.
Joe</font>
Yes,the threads on the tap.304 is very tough on taps,I use either sulpher threading oil (Texaco Sultex-D is what we use at work)or the wax sticks like "Edgelube".Might even try common candle wax.
Like JC said a reamer will help things,also an interupted thread tap may make things easier.Don't know if they make them in NPT,but the Greenfield EM taps work miracles in SS.
I typically use the 11/32 drill for 1/8NPT,it starts out loose,but since the thread is tapered it cuts to full profile anyway.
