CARBON SHEET
  • CARBON SHEET
    hello,
    which cutter is best for cutting 2mm carbon sheet by mill machine? and what is a best spinning rpm speed for home cnc work?
    thanks
    Yuck. Plan on buying a new mill after that job is done. It's almost worse than grinding. Mess city.
    Oh yeah, max rpm.
    [This message has been edited by Evan (edited 07-25-2005).]
      If it's just a flat 2D part consider waterjet. I've had a few carbon composite parts cut that way and it worked out well.
        thank you very much
