What thickness of mild steel or stainless would a 25amp plasma cutter cut? Thanks
Plasma Cutter
I have the 25 the same as Wolf. Sounds about right to me. With a new set of consumables it does a pretty decent job on 1/2" MS. 1/4" aluminum is a real struggle though. It cuts it OK but is pretty rugged looking. I run mine on 220V BTW. I've used this machine a lot over 5 years and am pretty happy with it.
RussI have tools I don't even know I own...
If you are looking to buy something make sure you check out Hypertherm. They are the leaders in plasma technology and usually will cut you a pretty good deal...my brother-in-law has a 95 amp one that he got a good deal on (though still way out of my price-range :-)) Anyway, if you can afford a bigger one, go with the bigger one...you'll be happier.
