Phase converter hookup
  • Phase converter hookup
    It appears my VFD has died. All I get is overcurrent fault, even with everything disconnected.
    I have a heavy duty phase converter I can use until I can come up with another VFD, but need to know if I will need a starter or can I just use a drum switch to start and reverse it. It is a 1-1/2HP, 220 volt motor.
    If I can hook it up on a pigtail, it will let me use the lathe in the interim.
    Jim H.
    JC,check your mail.
      If I understood your question and you are refering to the phase converter:
      For a self starter you'll need a start capacitor that you cut out once the phase converter is running. Since this is a temporary thing, wire in a switch and use a rope wrapped around the converter’s shaft to start it. Just switch it on and quickly pull the rope. You won't need to reverse it - the converter doesn't care what the lathe motor is doing.
      ________________________________
      [This message has been edited by Mike Burdick (edited 07-29-2005).]
        I have my lathe and mill both hooked up to a rotary phase. I don't run them both at the same time but they are both reversible with their respective controls. The mill was hooked to a static converter. It reversed in the normal way with the switch. I had a 9x42 Bridgeport with belt drive and it started ok. When I went to a variable speed Bridgeport it didn't start very well hence the change to using the existing rotary phase. I have a VFD on my belt sander because of its location I tied it into a circuit that needs to be kept on. I have been worrying about it being on all the time. How old was your VFD?
        Byron Boucher
        Burnet, TX
