I was making a rocker arm for my Marion 25 model, and while drilling an oil hole I broke a drill off in the hole.
The material is cast iron, about 1/4 thick
where it broke. The hole is a #70, and when
the drill was just breaking through it snapped.
THere is about 3/16 of drill in the hole, and it just protrudes into the bearing hole, .313.
It's about 1/2" from the end of the bearing hole.
I've tried to drive it through with the long part of the drill, and tried to puhs it out from inside the bearing hole. no luck.
Any ideas on how to get it out?
neonman
neonman
