I'm trying to turn down from .590 to .561 a piece of crs about 10 inches long. It's between centers.
When working the ends it turns fine with a nice finish but when I get to the middle third I get a pattern that is what I feel a 60 cycle affect would look like. It chatters in this area.
I've adjusted both speed and infeed and kept an eye on the tailstock live center tension. I've tried several bits and they are all freshly sharpened. The toolholder is a 2.5 inch solid steel cube made by a machinst. It uses 5/16 bits and they're kept close to the holder, not extended out in anyway. Also using a follow rest.
I'm taking extremely light cuts, on the order of .001 per pass as I know this is a slender piece to be worked over 10 inches long. I thightend up both gibs and the lathe is a SB9A in very good condition. ( I know the history of it)
Because I'm making an arbor I wanted to work between centers instead of using the chuck. Any suggestions besides taking it to a machinist or calling a priest?
Thanks for any help you can give....
[This message has been edited by Your Old Dog (edited 07-27-2005).]
