<font face="Verdana, Arial" size="2">Originally posted by Boucher:
J Tiers: I am not sure I understood what you were describing. </font>
grind the end to relieve it a little side ways and vertcally. Relieve the side a little. Knock off front corner slightly with a stone, just to avoid fine lines in the work. Don't put any real radius on it.
Cutting edge is now on the side. The end is slightly relieved so it won't drag.
That's what I mean.
Use it perpendicular to work. Force is towards chuck, not across work, aside from that due to rotation of the work.
Works best if work is shortish, or supported from rising by a follow or steady rest. But it will take a deep cut, and not spring the work as badly, nor chatter as much, in my experience.
