Anyone else have dial creep. Seems like when I making a bunch of parts. I can set the dial to zero out the start and after so many part 10 of so I get like .002 to .004 creep from the starting zero. Does not matter how tight I tighten the set screw either ( with in reason mind ya
). I'm starting to think it's sticksion between the knob and dial. I'm gona pull it apart and give it a good cleaning and hope for the best. If I can't fix this I'll have to make a good rig for a dial indicator or a cheap HF digital caliper. But was wondering if anyone else has this happen.
