I need a dynamic brake module for a 15 HP 230V VFD which has none on board. It's sold separately for big money by the maker. I've been looking around for used/old stock but they're scarce at my usual sources.
Most any of the stand-alone units will do provided it's capable of passing 40 - 50 Amps to the brake resistor and can be adjusted into the 375 to 400 VDC buss range.
The braking resistor is easy - a 3500 Watt (actual starting value selected for cold resistance) electric stove element running in air. I need the electronics part of a VFD's dynamic brakes.
I could cook up my own DB unit from a Schmidt trigger switching a honkin' IGFET transistor I suppose but my electronics theory while seeming crystal clear in my head hasn't worked out well in hardware recently. So I'm better off using the store-bought, already engineered stuff.
