wanted to try something with pic's...here goes.
occasionally I have to silver solder something, and holding the parts in alignment is a real pain. the commercial product below is worse that useless - complete POS
so i made of the following. fairly simple, uses solid cotters
the ball on the last one is for to-be-built arms (one day) the work surfaces are AL so SS doesn't stick and are thin so as not to be heat sinks. the small V-block is angle milled thin and peened onto the shaft, there's also a large one not shown. the larger black spring paper clips (if that̢۪s what there called) are good for clamping, although all manner of attachments could be made
[This message has been edited by Mcgyver (edited 08-04-2005).]
