Sorry...this isn't about dead cats or departed Jerry's. It may not even be OT if you need to repair pavement around your shop.
Our parking lot really suffered from the record amount of rain we got in June. It was rough anyway but the water really loosened it up.
I asked a local paving company to look at it to see if they could patch up some of the rougher area
The guy shook his head and said,,,"Nope...it all has to be replaced" Hmmm... $30,000.
Gulp!
Now I am a cheap bugger. I asked around and everyone said..no, the pavement has run its course.
I'm thinking...this isn't rocket science. We have tar, gravel and some sand.
I ended up trying to melt the old pavement with a tiger torch. It just sat there until the gravel started to explode.
After that you can break the pavement into gravel very easily. Heat the area up again....ooops...put on safety glasses first, and pour tar on the area to patch. Stir it around with a stick. It will pick up the sand etc and stick to the old base.
Shovel in the old gravel, pour in more tar and mix in a little bit of pot hole patch. Make sure the pot hole patch covers the fresh tar or it will catch on fire and is very hard to put out. Heat it up with the torch again and stir it all up. Spread it around and hammer it flat with a tamper. When it cools roll on a coat or two of sealer and bingo...you have fresh new pavement for far less than $30,000 and it is TOUGH. Far better than using the ol' pot hole patch. That stuff is next to useless on it's own. Have fun!
Russ
Gulp!
Russ
