I have to install a bunch of 24†long, 1.2†ID, 1.55†OD PVC rubber grips, on to some 1.25†OD electroless nickel plated tube handles. The end of the tubing where the grip will be started has an inch of threads and there will be adhesive spread over the tube. The grips fit the OD of the tube quite snugly.
I am unsure of the best way to hold the starting end of the grip out from the tube so the glue won’t be pushed into a bead at end of the grip. As there is an obstruction just past this stop point, this device must be removable with the grip in place. I am considering something like a split ring (flat, like a main bearing) with round end pins to space it away from the glued tube.
I am also unsure how to install the grips efficiently. Plugging off the tube and using air pressure sounds like my best bet so far. This will be a regular job so I need to work out something as simple and reliable as possible.
Also, can anyone recommend a good adhesive to bond the PVC rubber to the electroless nickel plating? It needs good thermal resistance (about 250آ°) and the ability to expand with the sleeve. I have ordered some different glues for testing, but if anyone has any experience, I would like to hear about it.
Thanks.
Thanks.
