Audrey got a new Whirlpool stainless steel Kitchen Aid fridge. (Whew) It alredy has a small crack in the freezer liner. Im pissed. It was 1800 dollars plus. It was a 6 month no intrest deal from leons furniture warehouse. They build **** nowadays. I should of braked up some 22 gauge and covered the old two door fridge i dumped but was working pwerfect (thirty years plus old though but nice two door heavy unit). I wish to repair the crack any suggestions. Thanx
Broken freezer liner
Why not have them fix it under warranty? Surely it has one. It's probably as crappy as the fridge, though.
The warranty on the Whirlpool water heater is a joke. It says on the box and on the tank the parts warranty is for nine years , but in the fine print it says they'll only replace a part once during the nine years. That means I'll have to pay for the next "Energy Smart" circuit board. The original one lasted one month.
Good luck.
RogerAny products mentioned in my posts have been endorsed by their manufacturer.
If the liner crack is in a wall ( vertical surface ) the repair need only be cosmetic. Air passing through will not be detrimental to freezer operation.
If the crack is in the freezer floor it must be made watertite. Liquids due to defrosting must not get into insulation.
If possible order a new piece and replace the cracked one.
If the liner cracked due to physical abuse sometimes a similar type plastic may be used as a welding filler rod for a working repair.
If it cracked due to its internal stresses I doubt it may be repaired succesfully.Jim
<font face="Verdana, Arial" size="2">Originally posted by Jim Hubbell:
. </font>
If it is new and cracked, get it repaired or replaced under warranty.
If it is out of warranty, the liner is probably high impact polystyrene, and can be glued or sealed with airplane glue or Duco household cement. It won't be pretty, but will seal it. RTV may peel off unless the surface is roughened.
It should be sealed.Jim H.
I'll stand by my post. The insulation will actually stay dryer if there is cold air allowed to circulate. The vapor barrier is always on the warm side of the insulation. The cold air is dry.</font>
True, but it will condense water on the outside of the barrier, INSIDE the "wrap". That leads to drips on the floor from somewhere on the bottom, as well as potential rusting of the "wrap".
Sealing the crack is so simple to do, why not do it?CNC machines only go through the motions.
I'm still standing pat. It makes no difference if it is sealed or not as the inner liner is engineered to " breath ". The repair need only be cosmetic.
I am a little puzzled as to how water can condense on a warm surface. If the insulation is bad there will be condensing on the warm side ( of the warm air ). As I said the cold air is dry.
The above applies to houses as well as freezers.
Jim
If you do repair it, an option is to use goop, or shoo-goo. It's tougher than the silicons, and it sticks really well. It will stink for awhile though, but so does silicon rubber.I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
This is what been sealing my freezer for the last 8 years. Cheap and quick. You should be able to purchase from a local home center.
http://www.shurtape.com/Default.aspx...16&ProductID=2John
I don't remember the trade name, but I've also bought stainless steel tape a couple of times. It's really good. Sticks permanently. And since it's marketed to the HVAC crowd, I'd think it'd work well in a freezer/refrig. I think I got it a HD or Lowes. Just stumbled across it the first roll I got.
It has a protective paper film on the sticky side that you remove before applying.
Of course a replacement would be best.Lynn (Huntsville, AL)
