Recent purchase of a JD 2555 has had me running a comalong more than the tractor itself. The 18.4-26 turfsaver tires don't like the black dirt with all the rain we have had. The grooves fill with mud and the tires simply spin without digging.
I acquired 4 used tires and rims 14.9-24 Ag tires, which will probably do better than the turf's. They are a little shorter, but should still work.
Before actually seeing them, I figured on a piece of solid steel, drilled and longer bolts, to use as spacers so that I can mount 4 tires to the tractor. When I picked them up, I realized that the spacer would need to be about a foot long, (10" between the rims with the tires stacked flat). So an adapter similiar to what I built for the Ford will probably need to be built. I used about a 4" pipe, with welded on 1" flanges at each end, both drilled, and one end tapped. Pipe was maybe 1/4" wall and held up fine with anything I wanted to throw at it.
However, with the addition of 6 times the Horsepower, I get a little nervous designing my own adapters for this new beast. It tends to tear things up without a second thought if they aren't designed heavy enough.
The new wheels are the same bolt pattern (lucky!!!) but use 5/8" holes instead of 3/4". I will need to drill them out, but don't happen to have a 3/4 counterbore with a 5/8 pilot.
Anyone got any ideas on the best way to handle these two problems?
David from jax
Have gun, will travel.
David from jax
