Arnak,
No problem if you wnat to make one. The profile for a rack cutter is straight sided with an angle of 14-1/2 degrees or 20 degrees depending on the type.
As someone else has pointed out you could use a tapered slot drill or end mill if you can get the correct taper and tip size.
This will be the stumbling block in getting those two to match. Tapered end mills are available off the shelf J&L do them from 1 degree up to about 12 in ones then the tend to go in 2's or 5's.
Only snag is with these the tips are about 3/32 or 1/8", OK for doing a 10DP rack but not a lot of good at myford size levels.
Again you can cheat and make a home made one.
You can even use a 'D'bit if you mill the bulk out first.
Here's one I did earlier
This was a "get John out the sh*te job" brass helical that needed to be done whilst a new one was ordered [ in fact it's still runing from 3 years ago
Milled on a 4th axis on the CNC but besides that it proves that a simple 'D' cutter turned up with a form button will work.
John S.
John S.
