I've been casting bullets for 30 years. Good advice to just buy pistol bullets already cast and lubed. Cast rifle bullets are another matter. With the velocities generated with rifle bullets, a hard alloy is needed. #2 alloy in the lyman handbook is about the softest I would recommend.
The amount of tin and antimony affects the way in which the mold fills out when casting, and the temperature the metal needs to be at the time of pouring. Large pure lead bullets (for muzzleloaders) are very difficult to cast without imperfections, visible or internal.
INMHO, the most important thing when casting and shooting cast rifle bullets is the bullet lube and lubri-sizing.
I've used alox/beeswax mix for years and found it good up to about 1900fps. This will probably start a war here, as every cast bullet shooter has his own favourite lube, both proprietary and home made.
I once used Galena(sp?) a bearing lubricant from a railroader friend of mine. I mixed it with a little beeswax and paraffin. Stunk like hell. Used it with pistol bullets. I'd fire a few shots, and other shooters would say, "What stinks?" or "Who died?". Great fun.
Keep your area well ventilated. Lead vapourizes when heated hot enough. I did so much casting indoors when I was a kid, it's a wonder I float at all when I swim.
just my .02
Rick.
just my .02
Rick.
