Grizzley (Shop Fox) vert/horz combo mill
  • Grizzley (Shop Fox) vert/horz combo mill
    ........In most humble, pleading (possible wheedling a bit) conversation with the wife, it was determined that after the insulated windows and pickup are paid off, it might be time for a mill.
    I failed to bring the HSM mag with me to work, but in their add inside the front cover they show a Shop Fox vetical mill that also has a spindle to allow it to be used as a horizontl mill.
    Would this seem to be a viable proposition? The price certainly seems reasonable enough. Anyone with experience using this machine?
    Rick
    Son of the silver stream ..... Bullet caster.
    There have been several vertical/horizontal mills of one sort or another over the years. Vn Norman made one with a pivoting head that could be used vertical, horizontal, or any angle in between, that was really handy.
    There was also a small British H/V mill made, the name of which escapes me, more on the lines of what you're talking about, that was a top-quality machine and apparently very well thought of.
    So...I'd say the concept is sound, certainly a "viable proposition," assuming it's constructed properly.
      In fact, editing the post totally screwed them up..... that bites.... they are gone
      Go to the chaski site and just search on "grizzly vertical horizontal" over all posts in general discussion" and you'll find a couple under "rust on the ways" and "grizzley vertical horizontal mill"
      That would be here:
      http://www.chaski.com/ubb/postlist.p...=gendiscussion
      [This message has been edited by J Tiers (edited 07-16-2005).]
        http://www.grizzly.com/products/item...emnumber=G3617
        Buckshot
        Is this the one? I like the concept but if you look close at the specs. the working envelope is pretty small compared to a similiar vertical mill.
        Jon
        Jon Bohlander
        My PM Blog
          Why Grizzly doesn't offer this machine with a 40 taper I'll never know. The horizontal spindle needs the #40's rigidity and torque to drive milling arbors. \
          It seems a third of my shop time is spent cursing the limitations of the wimpy R-8 tooling on my mill.
          I got the drawings done on a replacement quill and spindle having roller bearings and a #40 MMT for my BP clone. About $400 in materials plus bearings. Another round tuit job as if I don't already have a stack of them.
          [This message has been edited by Forrest Addy (edited 07-16-2005).]
            ........Thanks all. Moldmonkey, yeah that's the one. My mistake, I was seeing it as a Shop Fox in my mind.
            It's work envelope as a mill compared to what I have now (which is zero) wouldn't be a hardship. Actually I've been doing a bit of milling on the lathe so lets say it's not quite zero mill capability.
            I was actually considering one of the much smaller knee mills. Yet the horizontal function is an added interesting feature. Probably prove usefull in steam engine bedplate milling.
            I don't have room in my 2 car garage for a vertical and a horizontal mill. Heck, finding room for a bench grinder dedcated to tool grinding is a problem.
            Rick
              <font face="Verdana, Arial" size="2">Why Grizzly doesn't offer this machine with a 40 taper I'll never know. The horizontal spindle needs the #40's rigidity and torque to drive milling arbors.</font>
              I'm almost finished with assembling a Clausing horizontal mill from parts of two mills. It has a 30 taper spindle and I'd appreciate your thoughts on how hard that can be worked. It has a 1-1/2 HP motor - can one safely assume that any milling that doesn't overload the motor will be OK for the arbor/spindle?
              Mike Henry near Chicago
                Buckshot,
                Rockwell made a combined vertical/horizontal mill and these sometimes show up on the used market. They seem to bring around $2500 when in decent shape from what I've heard/seen. A friend has one and is pretty happy with it.
                  Mike, I have 30 nmbt taper in my vertical 2 hp that I have had for 20 years and I don't think you will have anything to worry about. It seems plenty strong and rigid. If pushed, I'm sure there will be other things complaining before the 30 taper.
                  Michael
                    For what it's worth, my h-mill has a 3MT taper, and I think when the drawbar is tightened, the key will shear or cutter will fracture before that taper lets go.
                    Don't all the NMTB tapers have "drive ears" anyway?
                      The spindle on this mill does have the drive ears so it sounds like there is nothing to worry about.
                      Forrest just had me worried there for a bit - parts for these are hard to find&lt;g&gt;.
                        Buckshot, I have had one of those H/V mills for a year now. I bought mine from the House of Tools in Edmonton. It cost a lot more than what Grizzly is asking.
                        I have 16" of vertical space under the spindle, table is a little short at 9 by 32. The X feed is smooth and strong.
                        The Horizontal comes with it,s own 2hp. motor, two arbors with spacers and the outboard support block. It is possible to change over from vert. to horz. without disturbing the vert. head.
                        The speed selections for the horz. should be lowered to allow for 6 to 8' cutters. should be possible with a pulley change.
                        When I tried a 6" x 1/2 cutter on test slot in mild steel, 1/4" depth of cut, no vibration or stress occured.
                        I love it! Doug
                          At least you can get arbors for that easily, loaded with spacers and bearing sleeves. B style that would be. IIRC, that's what you need, though.
                          Victor Machinery has 30 taper arbors.
                            I really like the look of the "Grizzly"
                            design, has the advantage of not having to change a setup when going from horiz'l to vertical, one thing I wish the table pivoted
                            like a true universal.
                            It also saves space if that's a concern.
                            Graeme
                              <font face="Verdana, Arial" size="2">Originally posted by GRH:
                              ...one thing I wish the table pivoted
                              </font>
                              Graeme,
                              I believe the table does swivel on this model -- 45 deg. right and left. It's not mentioned in the link, but in the catalog.
