Latest crazy addition to the shop...
  • Latest crazy addition to the shop...
    [img] http://images.andale.com/f2/129/111/8188590/1129732327611_weld_026.jpg[/img]
    Looks dangerous...
    I give up
    [This message has been edited by hoffman (edited 10-06-2005).]
    Techno-Anarchist
    Take out the space before http://
    Now take out the carriage return.
    [This message has been edited by Evan (edited 10-07-2005).]
      looks good to me.
        <font face="Verdana, Arial" size="2">Originally posted by hoffman:
        Looks dangerous...
        </font>
        It is very dangerous in that configuration... You really should install a saftey plug like this one for that explosed outlet:
        Also, you really want to call in a professional and have the remaining paint on that thing removed. That Leaded paint is bad if you decide to start chewing on any of it...
        If you take care of both of those saftey problems, there is nothing left to worry about...
        -Adrian
        [This message has been edited by 3 Phase Lightbulb (edited 10-06-2005).]
          [QUOTE]Originally posted by 3 Phase Lightbulb:
          [B] It is very dangerous in that configuration... You really should install a saftey plug like this one for that explosed outlet:
          Doesn't that "safety plug" require a grounding prong to be completely safe??
          RPease
            I'm pretty stoked about trying my hand at aluminum welding. I hope I can handle it. Everything you read has stuff about "squarewave", "pulse" etc. and I don't have any of that stuff...
            I can't even remember why I needed to weld aluminum in the first place anymore...
            Techno-Anarchist
              I like the ground wire just hanging there.
              Les
                It wasn't designed with a ground wire to the pedal. I need to make sure that it's OK to hook it up to the machine.
                Techno-Anarchist
                  did they tig weld aluminum before square wave?
                  Why you need to weld aluminum?
                  *Because it's the manly thing to do.
                  *Because it broadens your horizens.
                  *Because a lot of guys you know can't do it.
                  *Because one never knows when you may have to manifold a six pack of beer.
                  *Because rivets and bolts are so tacky on a serious aluminum project. (looks so homemade)
                  *Because it's one less thing that stands in the way between you and whatever your imagination can dream up.
                  You need more reasons I'll go on
                  [This message has been edited by Your Old Dog (edited 10-07-2005).]
                    lastest crazy addition....first new twinhorn milling machine....why? 6 lathes and no
                    idea how to run a mill! (i guess its time to learn)....Dean
                    http://www.neufellmachining.com
                      Whoaa... Dean is my new hero!
                      Techno-Anarchist
