Eureka gear cutter reliever
  • Eureka gear cutter reliever
    ??s on the Eureka reliever if anyone knows. : )
    First, the two ofsets appear to be 90* apart, is this correct? I only have the drawings in Ivan Law's book to go on.
    Second, If one wanted to make larger cutters, say 3 in rather than 1-1/2, would you need to scale up the whole device, just double the ofsets (& enlarge other parts just enough to allw this), or just use the same offsets while enlarging just enough to carry larger blanks?
    Looks like th offsets would have to double to keep same relief angles, am I thinking right?
    TIA
    uute
    EDIT: Yea, its late. The first eccentric (larger one) carries the indexing pawl, so it obviously must be scaled to advance the indexing hub. So it is the smaller offset which controles the rate of fall-off in relief. This one must be increased for the same relief on a bigger blank. Correct?
    [This message has been edited by uute (edited 10-12-2005).]
    Uute,
    I have made a larger one but just doubled everything up by 2 as I wanted to make standard 1" bore cutters.
    Here's a link to a small movie of mine working.
    http://homepage.ntlworld.com/stevens...les/eureka.mpg
    Staged movie but until you have seen one of these working it's not obvious how they work.
    One interesting thing is that it doesn't matter which way you run the lathe it will still rotate the cutter towards you because of the ratchet action.
    John s.
      This looks like fun, what is the name of the book please?
      hms50
      hms
        Gears and Gearcutting by Ivan Law
        Published by nexus special interests, ISBN 0-85242-911-8
        Usually plenty for sale on UK Ebay.
        http://www.ebay.co.uk
        Sir John
          very neat! are the plans etc are in this book? it looks like it could be univesal - if used with a feed can it be used to create a hob or other cutters?
            Sir John, Thanks!
            hms50
            hms
              Mcgyver,
              Yes the plans are in the book, based on one for 1/2" diameter bore cutters.
              It's a very good book this on most aspects of gear cutting. Aimed at the home shop guy it's straight forward and clear.
              No pages of higher maths that you can't do sod all about anyway.
              As far as I know no one has tried to use a Eureka for making a hob.
              One problem is the spindle has to revolve 12 times to the cutter revolving once due to the 12 tooth ratchet action so you will have to build a 12:1 reduction into the feed.
              As many DP feeds are weird, i.e. they don't work out to a full tpi dividing this by a 12:1 reduction would make some large ungainly gear trains.
              Sir John.
              [This message has been edited by John Stevenson (edited 10-12-2005).]
                <font face="Verdana, Arial" size="2">Originally posted by John Stevenson:
                Mcgyver,
                Sir John.
                </font>
                Dear John,
                I have built a modified Eurika to cut gear hobs. The lathe feed needs extra gears since
                the hob pitch has pi in it. I used a 42-44
                tooth compound to approximate pi/5. There is
                a problem with multiple passes and it cannot
                be solved by not opening the half nuts. The
                Eurika loses place when reversed. The
                hob blank must be retimed each pass. My mandrel has a hexagonal shoulder next to
                the ratchet for a short wrench. I also made
                a special tool to release both pawls at the
                same time. After making a pass I open the
                half nuts and roll the carriage back and
                re-egage them where ever I want. Then,turning
                the lathe by hand I look for the click where
                the hob is back in time. Since the ratchet
                has 12 clicks the lathe feed must be 12 times
                finer as well. My mandrel has a keyway to
                lock the blank in place. All work except the
                relieving is done on a plain mandrel. After
                cutting the main thread of the hob the blank
                is stained blue and put back on the Eurika.
                then the tool is run against the end to mark
                where the gashes need to be. After the gashes are cut on the mill the relieving can be done. The top relief is done with a square
                ended tool and timing is not too critical.
                The side relieving is done with a form tool
                with angled sides to match the gear pressure
                angle. I have made dummy hobs of
                aluminum but so far none of tool steel. I
                must get some proper materials and get back
                on this project. Best regards, Charlie
                  Charles,
                  I stand corrected, in fact your name looked familiar and I see from my emails you sent me a post to this effect in December 2004.
                  In that post you don't mention Pi but now you do.
                  Can you elaborate on this further as to me it just looks like 1/12 of a normal feed.
                  Sir John.
                    Charles,
                    Sir John.
                    </font>
                      This is interesting! I have seen an attachment that moved the compound in and out as the part rotated. What is the difference it the two approaches? I can see where the eccentric deal would be more capable of some more complex geometry... I think...
                      Techno-Anarchist
                        If the hob pitch is near 8 tpi then the lathe would need to be set 12 times finer or 96 tpi
                        since the lathe turns 12 times faster than the
                        hob. To get a more accurate pi lead a compound
                        of 71-113 gives a near perfect 1/5 pi. My next
                        step is to get some air hardening tool steel
                        and some stainless foil to heat treat it in.
                        My Eureka needed some friction packing to
                        keep it from turning too far when it indexed
                        and missing the next position. It took me a
                        while to get the pawels exactly the right length too. As usual, my apologies to anyone
                        reading this post who has never seen the
                        Eurika releaving device for the above gibberish. Someone should reverse engineer
                        the Baltzer reliever to get the 9, 12, 18, or
                        36 clicks that it could provide from the
                        same ratchet. Charlie
                          Thanks for everything guys! Especially the movie Sir John! i knew I seen somewhere here that you had built one of these.
                          Scaling the whole would probably be the smart thing to do, but I was thinking it is fairly robust, one might not have to upsize the ratchet section so much.
                          Interesting point Charlie. with a 36 point ratchet, how to control how many teeth the pawl picks up. Hmmm?
                          TA
                          uute
                            Charles:
                            Any chance you could post some pictures of you modified eureka?
                            I was puzzling on how to use one to relieve odd thread taps.
                            Cheers
                            Pete
                              <font face="Verdana, Arial" size="2">Originally posted by shapeaholic:
                              Charles:
                              Cheers
                              Pete
                              </font>
                              My general posting skills are not very good but
                              I have a Eurika album on the yahoo group
                              mwmills2 with a lot of pictures. Taps don't
                              need the same kind of relieving as hobs or
                              form tools so a simpler device could be made.
                              Someone made a small Eurika for clock gears
                              which was mounted on a shaft from one end instead
                              of between centers. With that method a chuck
                              could be fitted to the Eurika mandrel to hold
                              work that was not hollow. Worm wheel hobs are
                              similar to taps but do need all their teeth
                              relieved. Taps need plain relieving only on
                              the ends. The rest of the tap doesn't cut much. Maybe someone here knows how tap relieving
                              is done. Best regards, Charlie
