Boring Problem
  • Boring Problem
    I am making what looks like the nose section of a missle out of solid alouminum stock. I have to bore out the inside to match the taper of the missle cone. How would I go about getting this done. I have tapered something before but never reverse like this. My taper has always started from the inside and tapered outwards.
    Tapering an ID. and OD. with a taper attachment is basically the same. You can also form the ID. as well. What size is the piece and what machine are you using
    Bob Scott
      Generate the outside profile using mastercam then reproduce for the inside. I cut steps on the outside blue it and file to shape goes great very quick. Then just use a small long shank burr on the inside to clean out. After you produce the steps inside the bore using your mas cam dimensions cleaning it out is a snap. It will look pro Local high school teacher would probably help you with the mascam stuff if you dont have a clue about it. I use a lathe with a digital readout for odd shapes but a conventional lathe with dials will also work just as well.
        I am using a Fryer CNC lathe but have never had to do this operation before. I currently don't have Mastercam. We are waiting for the new fiscal year before I am able to get it. Thanks for all your help.
          Model? How big is the cone?
          How about making your own cutting tool? Or a cone rasp?
