Van Norman Mill Drive Chain
  • Van Norman Mill Drive Chain
    I recently acquired a Van Norman #12 in pretty good shape. However, the chain drive (toothed chain)for the power table will not stay on the gears. I'm told there is a different way to adjust the tension. Can anyone help?
    Thanks, Bill
    I have a VN but it is the bigger 22L.
    You might try
    http://finance.groups.yahoo.com/group/vannorman/
    I go there often when I need advice on mine.
    rock-
      Thank you, sir, I'll give it a try. The 12 was heavy enough to get out of the previous owners cellar. It doesn't look like the drive has worked for awhile.
      Bill
      <font face="Verdana, Arial" size="2">Originally posted by rockrat:
      You might try
      rock-
      </font>
        The motor slides left and right to adjust chain tension.
          I found that. The problem is that when you snug the chain up and rotate the drive by hand, after a couple of revolutions, the chain jumps and locks up. Trying to find out if the chain should real tight, slack or somewhere inbetween.
          Thanks, Bill
