ACME Roughing Tap
  • ACME Roughing Tap
    Working on a roughing tap for 1/2" - 10 tpi ACME thread. I cut a 10-tpi Vee thread, then cut out the root w/ ACME form tool (ground for 8-tpi).
    Sound reasonable?
    Better way?
    uute
    If you start with a 60* thread, full depth may not allow the acme thread to properly form. You will have to stop roughing with the V before nearing the width of the flat at the crest. May not remove much metal at all.
    Dont' know if it is a "better" way, but you can buy a tap that will rough and finish with the same tap in one pass. They known as Acme Tandem Taps. Drawback: pricey if only for single use.
    Not trying to be a smart a**, if you are looking for 10 TPI, why then cut out the root w/ ACME form tool ground for 8-TPI?
    [This message has been edited by ERBenoit (edited 10-24-2005).]
      Thanks for the reply ER!
      This was meant to be like the front half of a tandem tap, the roughing portion. So I cut the root w/ an 8 TPI tool so tap would not remove too much material from root (internal crest?) of hole - leaving some for the finish tap to clean up. Same reason the crest was cut to 60*. I'll try some pics later if I can.
      uute
      http://photobucket.com/albums/v300/u...nt=ACMETap.jpg
      and
      http://photobucket.com/albums/v300/u...=ACMETap-2.jpg
      [This message has been edited by uute (edited 10-25-2005).]
        Finised them up.
        Look OK, we'll see when I try to use them if the thread forms are too tight!?!
        http://photobucket.com/albums/v300/u...=ACMETap-3.jpg
