metal cutting speeds
  • metal cutting speeds
    I know that this is listed some where but I am not finding it. I am looking for the recommended cutting speeds for metal. Espacially for 4140.
    I am running a 5 inch 26 tooth cutter at 180RPM with about a 4 inch per minute feed. I think that this is too fast.
    The cutting speeds were/are listed in Machinerys hand book but I guess I am not looking for the right turms in the index.
    Thanks for any information you guys can give me.
    Charlie.
    Don\'t ask me to do a dam thing, I\'m retired.
    http://home.earthlink.net/~kcprecision/
    At 100SFM that would be 53 RPM...
    If that's a HSS cutter like I think it is, You're way to fast.
    Jim
    Jim
    Phinney Bay Machine Works
      Listen to your cutter and machine and learn to read the chips.
      By the way what kind of mill are you running a 5" cutter on?
        PBMW it is a HSS cutter and that is the reason that I posted this. The cutter sounded alright but the life of the cutter befor resharping seemed short.
        The chips are comming off the cutter rather small and they are a naterial color not blue.
        The mill is a Nichols mill that I picked up a year ago for $50.00.
        Thanks for the replys guys.
        Charlie
