AVG
  • AVG
    Well, it seems like the computer problems I was having a while back were due to the AVG anti-virus program. The computer was starting to crash while downloading email. Previously it would crash while trying to instal a program, or move certain files around between folders. The monitor would go into power save mode, and I lost all control via mouse or keyboard. Disabling the email scanning part of the program wouldn't take, and it would just continue to 'interfere' with the email. I did a restart to see if that would make the difference, but no. After more than two hours of trying to complete the download of a few emails, without a crash, I finally had to uninstal AVG, since it seemed there was no way to even temporarily disable it. Now the computer is working like it used to, but of course without virus protection.
    It seems like maybe AVG got fat, like windoze registry does, and started to cause problems the same sort of way. Hmm.
    Anybody else have problems with NFG- I mean AVG?
    I haven't seen any problems with AVG to date except that their server is really busy lately due to a new virus making the rounds. If you get an e-mail from the FBI or CIA don't open the attachment. As you might guess, the FBI and CIA don't e-mail people to tell them they have been breaking the law. Duh.
    You can easily disable AVG when it is installed. Hit ctrl-alt-delete to bring up the task manager and click the Processes tab. Highlight and kill the processes that are named AVGxxxxx. That will turn it off until the next reboot.
      I have the free version of AVG on three computers and have had no problem.
      GHop Shop
      GHop
        I use AVG free edition, I had do disable the email scanner as I couldn't get legitimate emails through, never found out why. Apart from that, no troubles. I use Mailwasher to delete unwanted emails before they are downloaded.
        Tim
          Hi There,
          I too have the "Free" version of Grisoft AVG and it works well for me. A while back, I found that AVG and Nortom Utilities would "fight" over email scannning and hang indefinitely and I couldn't get any emails.
          If you bring AVG Control Center and click on the email scanner, there is a "button" labeled "Disable Plugins." If you click this, you will disable the email scanner in AVG and then Norton will do the email scanning. The down end is that AVG will consider itself "not fully functional" and will occasionally let you know this fact.
          I hope this helps. Good Luck!
          -Blue Chips-
          Webb
            Anti virus/ spy ware. I started having a pop up come up in the start tray but coudn't find out were it came from everytime I started the computer. It didn't say anything exectp that are you sure you don't want it installed. Well after running Microsoft new spyware beta ver. we found out it was something AOL loaded when the Instant Message loaded the buddy list. pain in the seat cushion.
            Glen
            Been there, probally broke it doing that
            Glen
              Better than crippling AVG is to get rid of the McaFEE or Norton /Symantec POS and let AVG run without having turf fights.
              AVG is the ONLY antivirus I have found that is totally not a problem.
              Norton/Symantec at work randomly decides that a file which has not been accessed for months, and has been scanned several dozen to hundreds of times now has a virus, and deletes it. I notice it never can "remove" the virus, it ALWAYS deletes the file.
              I do not believe the assertion that there suddenly is a virus in there..... I know its "possible", same like its "possible" that the computer will leap off the table by itself.......
                Have used AVG for about 2 months. After first loading it I could not get email. Called my ISP, they said AVG would check all available emails before downloading. If any were suspect, it would not load any of them. Disabled email check and everything worked OK for a while. Then I could not get it to update. Deleted and re-installed, now it will update. It is OK as far as I can tell and less of a pain than McAfee.
                North Central Arkansas
                  I've recently installed AVG on two machines running Win98SE, and have had no problems so far. I installed but disabled the email scanning, and AVG doesn't complain. Click on the email scanner component, then click the Disable Plug-in button. Go to the General tab and click the box "Ignore fault condition of plug-in". I don't need the email scanner since my ISP subscribes to a scanning service.
                  Leigh
                  Leigh
                  The entire content of this post is copyright by, and is the sole property of, the author. No assignment
                  of title nor right of publication shall ensue from presentation of this material on any computer site.
                    Ought to mention that my AVG email scanner works exceptionally well.... I have not turned it off... It simply works, a ittle window pops up in the corner to tell me it is at work, it finishes, closes window, all is well..
                    And, I am still using OE for email, although the Mozilla web browser is in use.
                      Well, glad to hear that nobody else is having problems with it. I will re-instal it and see what happens. Thanks.
                        I used to use avg on my old machine and had no problems with it, but on my new machine I installed Avast virus scan free addition, and I am really happy with it so far.
                        http://www.avast.com/eng/avast_4_home.html
                          If you value your computer and files I can only attest from experience that it pays to have a good antivirus program. Not freebies. With the wild range of scumware, virus, popup's, trojans and worms you can not be without it. It used to be that you had to open a file from email to get hit, not so anymore. The new range of worms in the last couple of weeks are all self-excuteable (meaning they load themselves). I have seen the "bugs" take out a video card, hard drive and even the motherboard. Okay enough doom and gloom; here are some good programs:
                          These are free: CWShredder is a good small program that will help eliminate the "Cool Web" search pop up. Spybot is another freeware program that is excellent and has regular updates; HJT (Hijack this) This is a good diagnostic program. It will help you identify changes that may have occurred in the registry due to a virus and give you a chance to fix. Adaware is one more free defense tool. I use all of these daily. My virus program is symantec gold which I buy on a yearly basis.
                          Another thing to do is to use a good firewall, some of these are built into routers or can be actual software.
                          I have never seen antivirus (on its' own) take down a machine but I have had conflicts when I used some of the early Norton systemworks. Also one should regularly take out the garbage which means deleting old files, temporary internet files and the like.
                          Hope this is useful.
                            Well, I guess I'm going to need more help than I thought. I lost a few files tonite while trying to put them in a folder to send to the burner. I downloaded the latest avg program (which went fine this time with the old version uninstalled) but then I couldn't even start the installation program. Poof, out goes the monitor, and the only time it didn't go out, the computer was frozen. I can run any program that's installed, but I can't instal one at all now. I must have rebooted at least 20 times tonight while attempting to consolidate my stuff in prep for a re-instal of windose.
                            I opened the case and blew the dust out, checked for loose harnesses, etc. Fans are running, nothing mechanical is amiss. I've been meaning to instal another memory card that I have on hand, and I did that (computer down, of course, and static protection in use), but the computer wouldn't even boot up after that. Take the new card out, and it boots. Strange. I have one unused slot to put it in, and it fits and is the right type of memory, but somehow there's a problem- it could be with the slot itself. I did have to bypass that slot when I put the third memory card in some time ago, so I have slot 1,2, and 4 filled. That's only 128 megs total, so I shouldn't be having a problem adding another 64 meg.
                            Anyway, a friend is going to give this box an overhaul and maybe she will be able to tell me what's causing all these problems. She wants to wire my hdd into her computer and scan it, so maybe that will show up the evil villains. Then it'll get a re-instal of windows. It's about due, been about a year and a half now, which is about as long as it ever runs before it can't cough up that electronic hairball anymore.
                            Still runs solitaire really well, though. Thanks for all the suggestions.
                              "I have seen the "bugs" take out a video card, hard drive and even the motherboard"
                              Waitaminute. Stop spreading FUD. That is highly unlikely. Although it is theoretically possible to "take out the motherboard" on some computers I haven't seen a virus designed to do that since the Chernoyble virus and that was years ago. As far as damaging the video card or hard drive there isn't any way feasible for a virus to do that. Even the Chernoyble virus can't affect most current motherboards and even then it only happened under very specific circumstances. The motherboard wan't really damaged, only the flash ram was overwritten.
                              Current viruses don't attempt to disable your computer, that isn't what they want. They want to take over your machine and still have it running so it can be used to relay spam, child porn or be used to launch denial of service attacks on other web sites.
                              I'm not a fan of antivirus software in general since it doesn't matter what type you use it isn't going to protect your machine against all possible attacks. The faulty security design of Windows is the real problem. There isn't any such thing as a 100% secure computer unless it isn't connected to anything but Windows is so far from the desired state it isn't funny.
                              Free antivirus software like AVG is just as good as Norton and others except that it doesn't slow your computer down by 20% like Norton does since it doesn't check every file every time it is touched for any reason. That doesn't make the slightest bit of sense to do unless you consider that it is a USA made product and is subject to USA liability law.
                              Symantec has to be able to stand in front of the court and say "Yes, your honor, we did everything in our power to prevent the sad events that befell the plaintiff". Meaning that NAV checks a file every time it is dealt with in any way regardless of whether it actually makes sense to do so. This incurs a BIG performance hit.
                              AVG on the other hand only checks a file when it really needs to, like when it first is downloaded to your machine. It makes the assumption that it is clean after that. It is also a European product and they don't have to worry about ridiculous frivolous lawsuits under US tort law.
                              As for firewalls few routers have a real firewall built into them. They rely on NAT (Network Address Translation) to masquerade the IP address of the machines behind the router. This is as good as a firewall for certain aspects but does not include "stateful inspection" of traffic.
                              XP has a built in firewall and the version in SP2 includes stateful inspection of traffic. You don't need a third party firewall. Also, a firewall has nothing to do with stopping viruses. It is there to stop direct port attacks like the code red worm. These do not arrive via e-mail or by visiting web sites and rely on security holes in Windows services that use the internet in some way. Firewalls DO NOT stop viruses and anti virus software DOES NOT stop direct port attacks.
                              As for my own systems I don't use antivirus software on my client machines. All my traffic comes through my gateway machine and my web server which is in the internet DMZ of my network. It is secured via the use of appropriate software and proper configuration. My mail server checks all incoming e-mail for viruses by shelling out to DOS and running a DOS version of F-PROT which does the checking. There isn't a virus out there that can stop this check at that level. You can't even ping my servers and they have no known vulnerabilities.
                              Even on my machine at home which must use dialup access I use an undocumented "feature" of XP to dial in to my gateway machine at my office and connect via a network bridge to my DSL connection.
                              Bottom line is that although a virus or other malware isn't going to actually physically damage your machine it can cause a lot of problems. There is no 100% solution but there are things that you can do.
