diy spot welder
  • diy spot welder
    David, I saw the pic of your spot welder in another thread, its something i'd like to build.....so does the gang have any words of wisdom or particularly good tutorials/build sites out there you know of?
    That is a $159.00 Harbor Freight Spot welder, converted with a 8" stroke cylinder, a opto22 power-cube timer controlled by the Cnc mill computer.
    Footswitch activated according to Visual basic software. *press 1. or welder or press 2
    There is no reason it has to be that complicated.
    running between 2500 and 3500 microseconds per weld on the stainless.. so some timer that hits close is allright. (1.5-5 seconds)
    Operational logic?
    foot pedal?
    1)It clamps air solonoid
    2)timer to close and build pressure.. wait...
    3)turns on opto-cube relay,
    4) timer weld-time.. wait..
    5) turns off welder
    6) hold closed air till foot-pedal releases
    You can build the same with cube relay, two timers, pneumatic solonoid and a foot switch plus a 3-24vdc source for solonoids and cube relay. No computer needed.
    I have seen cycle timers that would do all this.. they are motor driven sequence relays.
    I can not see, manipulating two sheetmetal pieces in place, holding the "heavy" spot welder, clamping down the lever with your "other hand" and then working the switch for a exact time period to make a perfect weld. It was just too hard on a fat boy.. so.. I automated mine. I love the easy button. My welder hangs on a arm and I hold the parts and step on the pedal.
    Excuse me, I farted.
      Linsy Publication is a good place to start. I have made three from there ideas by taking high voltage transformer cutting the secondary high side off and putting layers of sheet aluminum to makeup a new secondary with only two raps around transformer.
        First you start with one of these:
        Unfortunately, that's as far as I have gotten so far...
          Ohh, you want to build one, not automate.
          A online pdf. I saved it in my cdrom library somewhere. I'll look in a bit.
          I keep threatening to catalog them. Thousands of pdfs. Yeah, I should number them and make a catalog cd. Information is only useful if you use it.
            "Information is only useful if you use it."
            Or can find it
            I have this book, PC PHD, shows all kinds of neato stuff with the PC, how to autmoate things, etc....I can't find the damn thing.
            -Jacob
              http://www.5bears.com/welder.htm
