transposing gear set for rockwell lathe
  • transposing gear set for rockwell lathe
    I have a rockwell 11in lathe model# 25-100 and I am trying to locate a metric transposing gear set or at least a manual for the set so as to make one myself. I have been looking for one on ebay and at machinery dealers for about a year and a half but its' an illusive little mother. Does any know if the gears use a standard presure angle (20, 14-1/2)? that would be nice, although I would like to try my hand at gear cutting at some point. I suppose I could do the calculations and figureout the gearing myself but It would be nice to have a guide. If anyone can help I would greatly appriciate it.
    Virtually guaranteed to be a standard pressure angle.
    The fundamental Problem you need to solve is how to add a ratio of 2.54:1 into the gear train. Classically, it's done with a compound gear of 127/100 teeth. (Then you throw in a 2:1 ratio somehow, to get the 2.54:1, but that's pretty easy to arrange.)
    127-tooth and 100-tooth gears are pretty big (and expensive), so sometimes approximations are used that are "close enough" for any sane use. 47/37, for example, is very close.
      thanks so much I knew I was over compliating this in my head. 2.54:1 ratio that I can do. and I bet your right about the presure angle I was just worried because I had seen an article about a back gear repair done to a similar machine and the guy was going off about the weird presure angle although those gears were helical and proprietary, alot of the other gears actually have boston gear stamped in them. well I will try that asap Thanks again
        Here are all the gear combinations between 15 and 100 teeth that will yield a
        ratio of 1.27 with <= 0.5% error.
        Desired ratio = 1.27
        19:15 => 1.266667 (-0.262467%) **
        28:22 => 1.272727 (0.214746%) **
        33:26 => 1.269231 (-0.060569%) **
        37:29 => 1.275862 (0.461580%)
        38:30 => 1.266667 (-0.262467%)
        42:33 => 1.272727 (0.214746%)
        43:34 => 1.264706 (-0.416860%)
        47:37 => 1.270270 (0.021281%) **
        51:40 => 1.275000 (0.393701%)
        52:41 => 1.268293 (-0.134434%)
        56:44 => 1.272727 (0.214746%)
        57:45 => 1.266667 (-0.262467%)
        61:48 => 1.270833 (0.065617%)
        62:49 => 1.265306 (-0.369597%)
        65:51 => 1.274510 (0.355103%)
        66:52 => 1.269231 (-0.060569%)
        67:53 => 1.264151 (-0.460556%)
        70:55 => 1.272727 (0.214746%)
        71:56 => 1.267857 (-0.168729%)
        74:58 => 1.275862 (0.461580%)
        75:59 => 1.271186 (0.093421%)
        76:60 => 1.266667 (-0.262467%)
        79:62 => 1.274194 (0.330201%)
        80:63 => 1.269841 (-0.012498%) **
        81:64 => 1.265625 (-0.344488%)
        84:66 => 1.272727 (0.214746%)
        85:67 => 1.268657 (-0.105770%)
        86:68 => 1.264706 (-0.416860%)
        88:69 => 1.275362 (0.422230%)
        89:70 => 1.271429 (0.112486%)
        90:71 => 1.267606 (-0.188533%)
        91:72 => 1.263889 (-0.481190%)
        93:73 => 1.273973 (0.312803%)
        94:74 => 1.270270 (0.021281%)
        95:75 => 1.266667 (-0.262467%)
        97:76 => 1.276316 (0.497306%)
        98:77 => 1.272727 (0.214746%)
        99:78 => 1.269231 (-0.060569%)
        100:79 => 1.265823 (-0.328915%)
        Regards, Marv
        Regards, Marv
          My Rockwell 10" made in 1966 uses gears with a 20 degree Pressure Angle. Hope this helps.
          I cut it twice, and it's still too short!
          Scott
