I was on the metal meet forum when I came across a thread on building an oven. this link was a complete site on building one. http://www.powdercoatoven.4t.com/
This is the link to the metal meet site.
http://www.metalmeet.com/forum/register.php?
This is what another poster said about his home buiilt oven its a great idea.
Here's what I did to build a powdercoating oven because a stove is just to small and it works perfect. I went behind an appliance store where they have there appliances they are throwing away and I got the biggest stand up freezer I could find and I got the cleanest stove I could find. The freezer only had plastic on the door so I removed that and tacked a piece of sheet metal on there,I took off the rubber gasket on the door and replaced it with the rope gasket they use on wood stoves and glued it in place with high silicone caulking,I took the stove controls out of the stove and mounted them to the top of the freezer and I put both elements on the bottom of the freezer on the inside only to find out I only needed one element and the whole thing works perfect. I had a whole exhaust system and mufflers in it and a set of 4 wheels at one time. the nice thing is the freezer was already insulted so i didn't have to do anything there, i suppose if you needed bigger you could get a double door refrigerator or weld two freezers together only took a couple of hours to put together and been working perfectly for 2 years.
Glen
Been there, probally broke it doing that
[This message has been edited by PTSideshow (edited 01-02-2006).]
Glen
