There's a taper pin that connects the leadscrew to the gearbox on my sheldon lathe. There is some slop between the taper pin and the piece that comes from the gearbox. The pin is some type of brass looking metal. I needed to get some stuff from Mcmaster and decided to get a new pin, however, the pins they have are 12L14 steel. Is that brass pin used as a shear pin to protect the lathe in case of a crash? If that's the case would the 12L14 pin be too strong and not act as a shear pin? What you all think?
Chris
Chris
