Dressing a CBN wheel???
  • Dressing a CBN wheel???
    To dress the wheel to it's hub you should use a ???
    To clean the wheel after uses you should use???
    Does anyone have any good suggestions on what type of wheel to use for gringing nickel-titanium???
    Is this a test?
    Diamond on the side, Aluminum Oxide on the face. Grind wet-Face wet, Grind dry-Face dry.
    Can't help ya on the NiTi. Sounds like the stuff they make eyeglass frames out of. "Memory Metal".
