Today I needed to turn down the ends of a piece of hardened and ground 1" precision shaft. I chucked my 6" 4-jaw into my big 4-jaw and dialed everything in nicely. Even though I had the chuck tight the shaft wanted to slip into the headstock. Even taking light cuts didn't help. Finally I was able to combine light cuts with the lathe's top speed of 1800 RPM and basically burn the metal off with a carbide insert (it was coming of in cherry red strands) still had slippage though. Tommorrow I have to do the other side, any suggestions on keeping it from slipping in the jaws? On this job I could put a small tack weld on the large OD so it's can't slip but in the future what are my options? What about putting some soft brass between the shaft and jaws? Clamp type shaft collars? Magic dust? What's the secret LOL!
-Christian D. Sokolowski
