The levers compound the tonnage put on them.
The scotchman will punch 1/2" through 1/2 plate easily, but you look, it is a 6" cylinder there on the end of the fulcrum arm about three feet away. Not sure how much pressure is pushing. No guage on that one.
You need a way to "guide" the punch, guide the shear.. Buying a complete unit that goes onto a ironworker is the "premade" deal. www.grainger.com has them, along with edwards. along with..
If I was going all the way again, I'd build a H-press, then outfit it with tubing benders and punches, and shears, and sheetmetal dies, and ..... Hard to let anything around here just do one thing.
I looked to see where you are? I got a H- frame sitting here rusting. No hydraulics.. but then.. HF has a 50 ton for $699..complete.
