Cutting Styrene Sheet
  • Cutting Styrene Sheet
    I need to cut some thin .120 sheet styrene sheet without it cracking any hints tips or ideas gentlemen. Thanx
    A 'hot wire' setup like RC aircraft builders use to cut foam with might work.
      Score it on both sides and break it. The borg sells a scoring tool (looks like a utility knife with a wierd blade) and a straight edge that's intended for high pressure laminate (OK Formica). This works well on all un-reinforced plastics.
      [This message has been edited by Forrest Addy (edited 01-22-2006).]
        I'd practice doing it with a soldering pencil with a thin tip. You might be surprised. I've also cut similar projects with a finising nail held in a pliers and heated with a small propane torch.
          You might try a table saw with a sharp plywood blade, if your saw alignment is good, works for me.
          JCD
            Score it on one side only and snap it away from the score. Scoring it on both sides exactly in the same line is near impossible. With styrene an ordinary carpet knife will do fine.
              Chainsaw
              Techno-Anarchist
                Just follow Evans advice, that carpet blade is the way to go
                  Haven't tried the carpet knife, but scoring it and snapping is the way to go. I use the high pressure laminate scoring tool myself. Ok, arborite cutter. Using heat in any way is messy, though it might work. I wouldn't bother trying it- it's gonna leave some raised edges for you to deal with, and if you saw to clean it up, you might as well saw to begin with. It'll start to get pretty scratched up.
                  Score and snap it, and if you can set up a jig to score both sides exactly opposite, so much the better. It's not easy to score both sides accurately by measuring, but if you get it right, there's very little edge treatment required after that. The fewer times you have to slide the sheet across something flat for some machining operation, the better.
                    Evan i tried my jonsered 52 cc chainsaw and made a mess. You were wrong as usual. Keep trying though. Thanx Madman
                      Flatten and sharpen the tip for a soldering iron and use it as a hot knife. I've done this with both pencil type and gun type irons. Once you have the knife tip made you can easily change tips when ever you need to. For cutting styrene, I would try using about a 60 or 75 watt pencil iron (less than 10 bucks at Radio Shack).
                      I cut it twice, and it's still too short!
                      Scott
                        Hand or foot shear
                          "Evan i tried my jonsered 52 cc chainsaw and made a mess. You were wrong as usual. Keep trying though. Thanx Madman "
                          Dummy. You have to replace the stupid "safety chain" that they come with with a real chain.
                          You're welcome.
                          Oh yeah, you forgot to capitalize "Jonsered".
                          [This message has been edited by Evan (edited 01-23-2006).]
                            That reply was for three phase i guess hes foolin around with computers again. Thanx Evan it worked nice.
                              madman..remember, that if you use any hot knife or melting process,be mindful of the not-so-good for your lungs vapors...
