how to identify and free up fairmont railway engine
  • how to identify and free up fairmont railway engine
    I have a stuck fairmont railway engine. I have no identification numbers and have struck out trying to identify the model. It has 2 flywheels and the radiator sits on top of the cylinder. Any help will be appreciated. Paul
    Somebody at Harry's Engine page might be able to help you;
    http://www.enginads.com/
    Those are neat engines, reverse by cranking the distributor around.
    Jim H.
      Lots of information here;
      http://motorcar.winkworth.us/engines/engines_index.htm
      Jim H.
        JC is correct, Harry's "smokestak" board is a good place to start. Do a search for Fairmont and you will find a few threads on this engine. Remember this is a 2 cycle engine and some were designed to run in either direction.
        Frank
          Worked on some fairmount railway equpt.
          may be same company located in columbia s, carolina-----fairmount tamper ph#803-822-9160
          BP
          snoopy
            spinrow, check your e-mail. I sent you the name and contact info for a guy who almost certainly help you.
              Thanks for the replies. I was able to identify the model of engine I have and find a source for additional information. I had tried google but you folks saved the day. Paul
