Drilling hardened steel
  • Drilling hardened steel
    I will need to drill some 61-62 Rockwell C steel at work. I have ordered a carbide drill bit from J&L rated to drill up to 65. Do you guys have any experience with this? What speed, how much pressure, do I expect a continous chip or powder comming off the bit? Use cutting lube? I have Molly D, recomemded for tough to cut metals such as stainless and titainium. This is not a production deal, for now just one 11/32 hole to take the head of a #12 socket head screw, to locate a part in a machine that is worn where it is supposed to locate. I can use one of the bridgeports in the tool room, which are in good condition, for this operation. Thanks for any advise that will help this to be successfull.
    Tom
    First,use the Bridgeport. Try about 1200 RPM to start.Don't use any lube or coolant.Use an air blast.what you should get is a fine ribbon that breaks easily-and lots of sparks-don't worry about about that.Don't be afraid to push it,just keep the chip clear. You should get a feel for it pretty quick. Good luck! Allen
      Get your part centered, then lock down all the axis. You don't want the table jumpin around when you start drilling.
        A die drill and slow speed with gobs of coolant will go like 'buddah' - just be careful when you break through the back side as the drill can snag and break. We drill a lot of armor that is around 55 Rc and that's how we do it.
          Thanks guys for the advise, Tom
