Another .6 crusader question.
  • Another .6 crusader question.
    The drawing for the cylinder head calls for a 1/4-28 thread and the text says that the hole is tapped 1/4-32. Which is the right tap?
    The way my luck runs I think I know which is the right thread. The one that I did not use.
    Don\'t ask me to do a dam thing, I\'m retired.
    http://home.earthlink.net/~kcprecision/
    The standard thread for a Gloplug is 1/4-32, so that is what I used. I hope that is correct as making a new head would be a pain.
      I said that I would do it assbackwards. A new head is in the works now. I have never had an engine that used glowplugs so did not have a clue.
        Don't throw out the head just yet, you can fix it with a Keen-sert, they are a solid sleeve insert.
        Doug
        Doug
          vmil3
          Where would you start looking for one of the inserts? At a hobby store that would sell this type of engine?
            I doubt there are inserts for glow plugs available, but it would not be difficult to make one 5/16" X something OD X 1/4"-32 ID.
            I did this to correct a similar problem.
            Jim H.
