.dwg to .jpg conversion
  • .dwg to .jpg conversion
    Another trick that I've used with nearly any WinBlows program (on Win2000 and WinXP, others may work):
    ctrl-alt-PrintScr will capture the image of the active window to the clipboard. Open Microsoft Paint and Edit-Paste the image into Paint. You can then save it as a ".bmp" file and convert it from there.
    Some programs override this somehow. For those, Alt-PrintScr will capture the entire screen to the clipboard, which can then be pasted into Paint.
    I know it's gross, and not precisely what you're trying to do, but I've done this in a pinch a number of times just so I could show what I was seeing to someone else.
    The curse of having precise measuring tools is being able to actually see how imperfect everything is.
    I forgot about exporting the drawing as a .bmp file and then converting it to a .jpg. (Slaps self on forehead!!!) Thanks for the suggestions, guys.
    Greg
    "The truth is incontrovertible, malice may attack it, ignorance may deride it, but in the end; there it is." Winston Churchill
      I need to convert some Autocad drawings to .jpg format so they can be posted on a bbs as an image. Is there any good free software out there that will do this? Is there another way to post a .dwg without first converting it?
      Thanks,
      Greg
        I had to "save as" a .DFX then import that to paint shop pro, then export it as a .JPG
        thats the way I have to do it.
          Menu choices, File then Export will allow you to create a JPG directly from autocad.
          James Kilroy
            I do cad-cam modeling and I use a viewing software ( 3d VIEW ) I can print from there and I am pretty sure I can save as a JPEG file. Check out 3d VIEW on the web and see if you can download a trial program.How big a file do you have? I may be able to translate to you and send it back if you wish
              You can save as a BMP file by using the BMPOUT command, then convert to JPG with any free file convertor.
              Phil
              PS There is a superb free file viewer called "e-drawings" which can be downloaded from the SolidWorks website
                Phil
                  Bump
                    paintshop pro has a good screen capture feature , Im supprised photoshop does not have that!
                      Most BBS software will let you save as BMP or Gif and most decent CAD software has an export that will let you save them in either of those 2 forms.
                        I've been using free software that I got here:
                        http://www.pdf995.com/pdfedit.html for producing PDF files from AutoCAD drawings that works very well.
                        Bill
                          I'll 2nd the .pdf printer for drawings. You can zoom and pan around in them instead of squinting down to the last pixel. Den
                            I may be wrong, here. If I am, it's because I can't see a way around it.
                            When I scan anything, be it a letter, in B&W or a photo, and try to save as a JPG in PSP, it always comes out larger than the scan, because PSP has a native res of 24 bit color. HUGE files.
                            If you wish to post these files, find some other graphics program, unless the recipient has fat pipes.
                            I have to see if Corel Draw will do better, or Adobe.
                            George
