Hardcase hardware(?)
  • Hardcase hardware(?)
    Hi,
    Just curious if anyone knows if the hardware on these cases is proprietary (end caps, latches, etc.)?
    http://www.scopeguard.com/IMG_0110l.jpg
    If not, do you happen to know where it can be purchased?
    -SD:
    I would say the latches are off the shelf and probably everything else.
    I see it a lot on what they call road cases for musical stuff.
    Should not be hard to find.
    Gene
      Have seen somthing like those... may be the same.
      McMaster-Carr item # 10425A88 look like it could be it.
        Look here,
        http://www.case-ware.com/products.html
        Gene
          Also may want to look for "Flight Cases for musical instruments. All sizes, All prices.
          BFH
            Thanks,
            I wasn't interested in buying pre-made ones, like the Scopeguard cases, I already have quite a few. They’re outrageously expensive. Thought I'd try making one myself.
            -JW:> )
              Smoke
              What you are looking for is recessed catches and handles etc. Try these guys http://www.reliablehardware.com/shop...gory/reclatch/
              Tin
              Ad maiorem dei gloriam - Ad vitam paramus
                Thanks ... exactly what I was looking for!
                -SD:
