External Splined Shafts
  • External Splined Shafts
    My Friend has a Very Old Bulldozer at his Farm. It requires new Stubb Shafts Built. They are basic but have Splines on the outside Diameter. Any tips on Material and Machining Techniques would be Appreciated. Thanx Audrey
    audrey, by any chance this dozer have a hydraulic cylinder or two missing/ damaged?
      This wouldn't happen to be a MeadSpeed Cat would it?
      My dad has one.
      Sid
        <font face="Verdana, Arial" size="2">Originally posted by docsteve66:
        </font>
        No It Doesnt have Hydraulic Cylinders Missing yet they All Leak and many of the parts are in Dire need of Some Help.
        It is the most Festered Piece of Junk I have ever Worked on. Ha Ha Audrey
          audrey:
          4130 or 4140 case hardened, double tempered. Make it like the orginal would look like if it was not broken.
          Bugs Bunny made me say it...
          Actually I was remembering "Sheridan's Ride" in "Bull of the Woods" - even funnier now!
            Are you talking about a PTO? Similar to what one sees on farm tractors? If so, why not buy an adapter at a farm store and then you have the splines, but then all you have to do is weld the adaptor to the old shaft and perhaps machine the weld.
              <font face="Verdana, Arial" size="2">Originally posted by Cliff Lawson:
              Are you talking about a PTO? Similar to what one sees on farm tractors? If so, why not buy an adapter at a farm store and then you have the splines, but then all you have to do is weld the adaptor to the old shaft and perhaps machine the weld.</font>
              No I was specifically saying a Bulldozer. Thanx Audrey
