Will 'SK 30' taper fit '30 int'?
  • Will 'SK 30' taper fit '30 int'?
    Does anyone know if an SK 30 tool will fit in a mill that has an 30 int taper?
    Thanks,
    Ben H
    Same taper but I think SK is like CAT or BT in that it will be meant to receive a pull stud and therefore won't have the straight neck of a standard no. 30. Still might could use the SK in a standard no. 30 machine but might need longer drawbar and might need metric threads on said drawbar.
    CAT 40 for example can be used in a standard no. 40 machine if the machine has a long enough draw bar, as both CAT and standard 40 have 5/8-11 internal threads.
      As far as I know SK 30 does have an internal thread. I can make a drawbar to suit no problem. My main concern is if the taper will fit. Thanks for the reply D.
      Ben
