  • 4130
    I'm thrying to find a piece of 4130 that is 2.5" od by 1.5" id 12" long. Anyone have any sources? Yes I did the google search,so don't suggest that!
    Thanks
    Rob
    You may have to get 2.5" round bar and bore it out. 2.5OD and 1.5"ID doesn't sound like something you can get off the shelf.
    Albert
      Try Speedy Metals out of New Berlin, WI. They have a toll free # 1-888-744-4140. I have bought some 12L14 from them but they should have 4130 also plus they were reasonable for small orders as well as shipping. They have stuff on e-bay but found it cheaper to just order direct.
        Hopefully this won't set you off, but I found lots of information and some places that sell 4130 by going to www.dogpile.com and searching for 4130. Its a good search engine that I have a lot of luck with. Give it a try and see if that helps.
        Best of luck and happy holidays.
          Rob
          Any steel distributor should be able to get it for you. I got 8" seamless 1" bore high pressure pipe from a local distributor. It should be easier to find in the Chicago area - check with US Steel.
          Do a search on www.thomasregister.com
            Sometimes you just have to post it for the doors to open! I've been looking for a month and the largest i've found is 2". So I figure I would see if anyone out here had a source. after I posted my inquiry I've found 3 places so far!
            Thanks for the help, maybe I'll even find some closer then 1000 miles! If not at least I've found some.
            Rob
              metalmart.com is a decent source for small amounts of all sorts of metals. cut to the nearest inch.
              The early worm gets eaten.
