OT: Basic Question About LED’s
  • OT: Basic Question About LED’s
    As Dvido mentioned voltage spikes are going to be your LED’s biggest danger.
    The way to avoid this AND to control the brightness at the same time is to use a voltage regulator. (LM317 Radio Shack aprox. $2) This plus a 5K-ohm trimpot and 240 ohm resistor and you can build a voltage regulator that will eat any incoming spikes and accurately maintain the output voltage to the LED’s. Also with this no current limiting resistors are needed.
    The Lm317 is a three-legged device (Looks like a power transistor) and can control 1.5 amps.
    Power comes in on one pin and goes out on another. Between the output and the third pin is the 240-ohm resistor and from the third pin and ground is the trimpot.
    D'y know.... voltage spikes have yet to blow ANY LED I have seen.
    There is indeed a max current on an LED, but in general, they will take quite a bit of current, more than the continuous limit, if it is in the form of a short pulse.
    There are applications I have seen which happily pulse the LED with 2, or 3 , or more times the max continuous, and operate for years. They use very short pulses, and rely on the eye's "peak detector" to increase apparent brightness.
    An LED functions as a voltage regulator, it is a fwd biased diode..... The volts are lost mostly in the dropping resistor, IF you don't use a max-length string, with the acoompanying very small value resistor.
    I'd be very suprised if any "voltage spike" that is in the forward biased area would kill them
    If you have a max "load dump" pulse, you might get closer. I forget the length of time spec'd for those, but it is longer. Still, a reasonable resistor will allow accepting even that. It is only about 40V for 12V autos.
    BTW, the voltage regulator chips mostly have a 35V limit.... lower than teh load dump voltage. The regulator will need more protection than the LED...... unless you use a type with 65V limits.
    [This message has been edited by J Tiers (edited 08-18-2001).]
      I have a panel that I am lighting with a total of 18 - 2mm x 5mm rectangular LED’s on pigtails. I don’t have any specs on the LED’s but they seem to like 2.2-2.5 volts. They will be wired into a dimmable vehicle dash lighting circuit so I have about 14 volts to supply them.
      Should I wire 3 banks of 6 LED’s in series and parallel the banks, wire in parallel and reduce the voltage with resistance, or perhaps something else? The first option seems to make the most sense, but obviously I am far from expert when it comes to electronics.
      I wouldn’t mind adding a little pot so that the brightness could be fine tuned to match the other lights. How much current will 18 of these little guys draw?
        calculate for each red LED drawing between 15 and 30 mA.
        I = V / R
        R = V / I => 14 volt / .030 Amp
        R = 466 ohm resistor for brightest
          Joel,
          LED's are current devices and are typically all wired in parallel with one current limiting resister for each LED. Wiring in series can result in uneven lighting. A single dimmer pot can be used to control the overall light output.
            18 LEDs at 20 ma each will be about 5 watts of power on 14vdc. Unless you use a wirewound pot that's too much for an ordinary pot to dim. Usually for dimming large numbers of LEDs such as in displays etc pulse width modulation is used. This is trivial with a 555 timer IC and a small power fet.
              You should be able to string them in series groups of 4 (maybe 5 depending on LED) each and a dropping resistor (for each group). Now the resistor is only dropping about 4 - 5 volts at 20mA so 1/4W resistors should be fine.
              The 4 groups will then only draw 80mA or 1.2W on the 14 volts.
              I'd combine this with Evan's 555 pulse width timer and an n-channel, power mosfet thru which all of the groups return to ground.
              That way, everything is nice and cool
              Den
              [This message has been edited by nheng (edited 03-01-2006).]
                You're wiring these into a vehicle, so you basically have 12 to 14v to play with. Four leds in series will need about 9 volts to light, according to your data. Three in series will need about 7 or so. Three in series will give you the option to make 6 strings to wire in parallel, thus 18 leds can be powered decently. No other combination except 9 strings of 2 leds will allow you to light all of them without having to have a resistor for each one. Use 6 strings of 3, and 6 resistors. For each string of three then, add a series resistor of about 150 or 180 ohms. The current draw will vary as the alternator brings the battery voltage up, so maybe use the 180 ohm resistors and be a little safer with the current draw through the leds. With the battery voltage up to 14 volts, the 150 ohm resistor will allow 50 ma to pass through each string, which is usually a maximum. Using a 330 ohm resistor will drop the current through each led to about 20 ma, so there's your range of resistor values.
                Now a potential problem- if the dimmer is powering only these leds, then they will always be bright, since the dimmer is just a variable series resistor inline with the dash lights. It's not a potentiometer. Because the dash lights have a much higher current draw than the led array will have, the resistance of the dimmer is way too low to give a proper dimming action to the array. But you stated that you would be adding this array to the existing dash lights, so they will dim ok, though they may go right out before the dash lights get very dim.
                The led array will look to the dimmer like one, maybe two extra dash lights, that's all.
                Most leds, if of same color and type (coming from the same batch, basically) will be pretty closely matched, and it will be unlikely to have a noticable brightness difference between any in a string. If me, and one led appeared to be weak in a string, I would eliminate that one and wire in another.
                You didn't say if you were going to mix colors with these 18 leds. If so, you'll have to make equal strings, like each string would have a red, a white, a green- whatever. If you make a string of greens, for instance, and parallel that with a string of reds, you'll have to calculate a different resistor value for each string so each will draw an appropriate current. If you do a mix and make each string the same, the calculated resistor would be the same for each string. Different colored leds have a different voltage drop so you would need to have that data before you could calculate for the resistor value.
                [This message has been edited by darryl (edited 03-01-2006).]
                  Most non-high brightness LEDs are about 1.2 to 1.6V drop.
                  Some new high brightness types, like the white and blue ones, are up to around 4V, IIRC.
                  We happily use strings of several old-type higher-brightness LEDs on 15V in our products. No problem.
                  In fact, since they are current-operated devices, wiring in series is one of the better ways to get them the same brightness. You know the whole string gets the same current.
                  As for dimming, I wouldn't count on them dimming along with incandescent lights at same voltages. Almost certainly they will not, since their brightness is not related to applied voltage in the same way as an incandescent bulb.
                  But they may be close enough for you, depending on the chosen series resistor, etc, etc.
                  [This message has been edited by J Tiers (edited 03-01-2006).]
                    Excellent dimming response synced to the dash lights could be had by controlling a 555 timer duty cycle with a home made opto isolator consisting of a small dash light in a film can or similar together with a cadmium sulphide cell used as the timing resistor for the 555.
                      Thanks for all the information.
                      I measured the supply voltage at my preferred dimness setting and it is 11 volts. 13 volts is the maximum the dimmer appears to provide to this circuit.
                      I tried wiring up a bank of 5 and a bank of 6 to see how the brightness compared and the bank of 5 looks pretty good. Since this is backlighting, I can add 2 more led’s without too much trouble and keep it simple by going with 4 parallel banks of 5 led’s in series. I am unable to detect any difference in brightness between any of the led’s in the array (all green). The max voltage per led should only be 2.6 volts so it looks like I will be ok – unless I am missing something.
                      Sorry Darryl, I don’t quite understand; are you recommending the 6 string of three and 6 resistors so I can get the brightness spot on? Would I be better off if I series wired 10 banks of 2 paralleled led’s instead of the 4 banks of 5, or is this just a matter of preference?
                      As was mentioned, when the dimmer is turned down very low, the led’s go out. Fortunately, this doesn’t happen within my normal range of adjustment, so it indeed appears to be close enough.
                        As mentioned above, an LED is a current operated device. This differs from a standard light bulb which is voltage operated or rated. The problem is that they will attempt to regulate any voltage placed on them to a relatively constant value (voltage value). So a LED with a 2.3 volt characteristic that is powered directly with a 12 volt source will try to bring that voltage down to it's 2.3 volt level - by drawing a lot of current. Instant fuse or flashbulb effect, small amount of smoke is released and the LED no longer works.
                        This requires that a current limiting resistor be placed in series with the LED to limit that current to a safe value. That resistor is calculated by the supply voltage minus the LED operating voltage divided by the desired LED operating current. The LED operating current determines the brightness and should be limited to the max that the spec sheet shows for safe operation.
                        Unfortunately, some "LEDs" today are actually a combination of the LED and the series current limiting resistor. Such combination devices are operated more like a standard light bulb and if they are supplied with the rated voltage, an external resistor is not needed. You MAY have combination devices. You should determine which they are before deciding on a circuit. If at all possible, get the manufacturer's spec sheet.
                        If that is not possible, you may have to experiment with different circuits to determing the best.
                        As for putting them in series, results may vary. I had a similar application and I contacted the manufacturer. They said that THEIR devices were matched as close as possible but they could not guarantee anything. I had an indirect lighting situation so I put two in series and it worked out OK. They did seem fairly well matched. But they were all from the same batch and if I have to replace any of them later, results may vary.
                        Chances are, series operation would be OK. Six of them in series would be about 13.5 volts from your figures. If they are operating at 25 ma then the total current would be 3 X 25 = 75 ma which any automotive dimmer should be able to handle. An additional series resistor should be added to EACH series string. It should be (I am using 15 volts for the supply to be on the safe side) R = (15 - (6 X 2.25)) / 0.025 = 60 Ohms. A 62 ohm resistor is the closest standard value. Wattage is low so a 1/4 or 1/2 Watt resistor would be OK.
                        Make it fit.
                          http://www.superbrightleds.com/led_info.htm
                            I just finished a "ultrabright" white LED design... It is more interesting than you might think. Specs say that your LED is probably 50,000 hours reliability... that's great - but the real world can bite...
                            When you are a long way out on the end of the wire - voltage may be poor - and spikes may be large. Temperature will affect the Current - Vf numbers a lot. Running pulse style will allow more "apparant" light to come from the LED - if you like.
                            Your battery wire also hooks to the starter. It hooks to a battery that gets cold in winter. It has nasty motors every where (spikes high and low). Automotive regulators typically should be rated at 60Vin on the line. They are go see 4.5 V at times as well. be safe at those numbers.
                            Current is affected by temperature and process. You can't count on "consistancy". So allow a good safe operating area. If you can, use a good "low drop regulator" to drop a 1/2 Volt or so to your LED operating voltage. That way, the regulator can be rated at 60V - and protect your LEDs from blowing.
                            You don't need "high precision" - just to keep the LEDs from Blowing - and you want to look at "safe operating region" numbers.
                            BTW - I'm building some lights for my boat. LEDs are getting EXTREMELY cool... LOTS of light. Putting them on my car's interor operating lights - as well.
                            good luck.. much good has already been said...
                            --jerry
                            dvideo
                              I just picked up an LED head lamp (for wearing on your head). It has a one watt Luxeon LED. Holy crow! Is it ever bright! You cannot stand to look into it directly. It's as bright or brighter than my three D cell maglight, throws a beam just as far and runs on three AAAs.
                              It has a strobe mode that looks just like a xenon flash. White LEDs are really improving lately. In a couple of years they will very likely be practical for most lighting situations.
