Backplate
  • Backplate
    A while back there was a thread that recommended a company that had unfinished backplates. I have searched but with no luck. Anyone remember or know the name of the company? Thanks
    Look here
    http://www.victornet.com/
      "The usual suspects" (Travers www.travers.com, MSC www.mscdirect.com, etc.) carry Bison backplates.
        Sprint car driver:
        I was involved in a thread on looking for a source for cast iron for back plates and someone suggested Victor Machinery (see above site posted by Larry Nicks) They have a 6" by 1/2" thick rough back plate for $12.50. I have made two out of cast iron free weights that turned out ok. The reason you probably didn't find the other thread is that I mistyped cast iron and couldn't chang it so numerous responces said "cast iton" (I think).
        I paid about $6 for the 10# cast iron free weights at Big 5 Sporting Goods here in California.
        Dick
        Dick
          SprintCarDriver:
          The Bison brand backplates are high quality cast iron, well seasoned, and well worth the money. If you have a threaded nose and want the best fit get an unmachined blank to fit it perfectly to your spindle. For the taper lock type(A & L spindles) and the Camlock (D1-4 etc.) buy the semi-finished. They are properly machined to fit the spindles and will only require machining the backplate surface to mount the chuck only.
