Table Feed Drives
  • Table Feed Drives
    I have a question about the aftermarket table feed drives that are used to move the cross feed tables on mills. "here is an example of one: http://grizzlyindustrial.com/fcgi-bi...=item&kw=G5964
    I'm investigating using one on an ornamental woodworking mill; reason being it looks like it would work and they are significantly cheaper than the motor drives sold for my machine by the manufacturer ($800). For a look at what I'm talking about see http://benchmark.20m.com/tools/Legac...alkAround.html
    I've already looked at the table feeder torque / speed range and it looks compatible to my machine.
    My questions are:
    1. How is the movement stopped; do these have clutches in them or is there a switch involved that actually removes power from the motor?
    2. Do you think they would live running continuously? I could probably use them 2 or 3 hours straight. It wouldn't be any problem for me to install a muffin to provide cooling air.
    3. Does the feed direction lever physically engage direction changing gears or is it just a switch that reverse motor polarity?
    PMB
    Surplus part houses have tons of smaller motors in stepper, PMDC, and AC. Roll your own drive - or adapt a commercial unit. The drives for the Bridgeport type mill tables have limit switches to prevent over travel.
      The lever engages the gears and starts the motor in whatever direction you throw the lever. When you disengage, the gears stop instantly while the motor winds down.
