Hey all-
I'm working on a benchtop plastic injector. I'm making a mold for a model railroading part which is basically two washers connected by a bar. It's 1/16" thick by 1/4" widest and 1" long.
To make the washer shapes in the mold (6061 alum) I was going to make a cutter out of drill rod - 1/4" dia with a 1/8" center bore(reamed). It only needs to cut 1/16" deep with a flat bottom (smooth finish desirable).
My question is I don't have any grinder set-up for "fixing" the cutter if I harden it (torch and water dip). It only needs to cut 10 cores in the alum and thats it. Will it last through that without hardening it? Or will it distort so little if I'm careful with the heating and dip that it's not a problem. It won't matter if it's off 0.010" but it should fit tight to the pins on the railcars.
Suggestions? cheap suggestions - I ain't sending it out.
Thanks-
Kevin
Thanks-
Kevin
