Shaper lubricants
  • Shaper lubricants
    I am acquiring a South Bend 7" Shaper. The plate on the side indicates that the sump has a 1 quart capacity. What kind of lubricant is supposed to be used in the SB Shaper?
    The oil specified by S-B for the shaper is their Part No. DE1602 which is defined as: Machine oil Saybolt Universal viscosity rating of 150-240 seconds at 100 degrees F.
      O.K. Please translate this into terms a Southern-born Tinkerer can understand.
        Hey Al I know what you mean. I took the information I gave you and looker in MSC catalog to see what you can buy from them. I couldnt find an exact match but it looks like a light weight gear oil would be OK. I would use the lightest weight gear oil you can get, possibly from a farm equipment supplier. Dont use motor oil, wrong addatives.
          J & L Supply lists Vactra No. 2 and 4 Way Oil Lube (in 5 gal. buckets), Mobil DTE Series Circulating Oil, and Mobil Velocite Oil No. 6 & No. 10 Spindle Oil (in 1 gal. cans). I am going to call J & L tomorrow and see what they recommend.
            Medium-weight machine oil -- ISO 32.
              Would this be something like Electric Motor oil? I hate to sound ignorant, but my local hardware and auto parts stores don't have much industrial machine savvy.
                Al,
                I think you'll be very safe with the Mobil Vactra No. 2 Way Oil. It has an ISO of 32 and a Saybolt Universal rating of 166 which is in the SBL required range of SUS at 100 degrees F of 150 to 240 seconds for "B" type oils. The ram plus other sliding (way type) surfaces are pressure fed from the reservoir and you want the protection of a way type oil.
                See:
                http://www.mbendi.co.za/mobilsa/prod...dustrial_t.htm
                See more data at:
                http://dallnd6.dal.mobil.com/Apps/DS...3?OpenDocument
                This is what I have in my SBL 7" and it pumps fine. I liked the outstanding anti-wear performance and excellent protection against rust and corrosion. Mobil Vactra Oil No. 2 is recommended for horizontal slideways on small- to medium-size machine tools, where the projected load does not exceed 5 Bar for flat ways or 2.7 Bar for Vee ways.
                Good luck,
                Jim Larsen
                  Forget your local hardware store, unless it happens to be one of the three remaining "real" hardware stores in the US that hasn't been taken over by Ace, Aubuchon, etc.
                  You'll need an industrial supplier. Get catalogs from MSC www.mscdirect.com and Travers www.travers.com and maybe J&L (don't know their URL offhand). They'll have the oil you need. Travers seems to be a little cheaper, generally, than MSC, but MSC has slightly faster service. I've used both and found both of them totally reliable.
                    Thanks, guys!! It'll be a day or two before I need the oil and a real good clean-up is first thing on the list.
                    Al Messer
