My week this week! My workshop videos.
  • #31
    Hi Guys, part 3 of the workshop rebuild series, actually in the workshop itself. Still quite intensive, but not as difficult or time consuming as the Church lane end. Enjoy, like, subscribe, and be amazed that I actually completed it without having a complete meltdown!!
    https://www.youtube.com/watch?v=FeWVEVSKjgY
    Man who say it cannot be done should not disturb man doing it! https://www.youtube.com/user/philhermetic/videos?
    • #32
      Back to video this week chaps, part 2 of the workshop tour, Beyond the sliding door! Like subscribe, and enjoy, comments and questions very welcomed!
      Phil
      https://youtu.be/jebnxWfQdHY
      • #33
        Hi Chaps, having mainly recovered from my Lurgi, I am back at work on "light duties" so in the last couple of days, I have been building the new straight flue to try and cure the forge smoking problem. I have built a coupler/ hinge to join the new flue to the old one, and to install and maintain the flue extractor, and so that I can lower the flue in windy weather, as we do get a lot of wind in winter and early spring. There is also a slideshow of rebuilding and upgrading my BEN patents air compressor. Like, comment, subscribe if you want, but above all, Enjoy!!
        Phil
        East Yorkshire
        https://youtu.be/TWi8wMpYLTA
        • #34
          Phil if you stand the hinge pin itself a couple inches farther back from the stack itself it will allow you to easily accommodate an internal astragal to the stack. The astragal will give the stack draft properties very near what they were prior to the hinging retrofit.
          Also prior to corrosion weaving its magic on the stack walls adding truss rods to the stack will increase strength tremendously without adding a lot of weight. That will minimize chances of bending during lowering and raising functions.
          • #35
            Thanks Franz, only just seen this as I cut short my forum browsing last night as I was falling asleep! I have finished the flue connection today, and did put tie rods on so that the vertical weight of the flue is carried to the wall and roof rather than the lower section of flue. As the flue had a former life on an oil fired boiler, there is corrosion, but it now wears an internal coat of veg oil topped out with a layer of hard creosote from the early lighting tests before I learned to run it hot and fast, to get rid of it. Next job will be to modify the outlet of the flue fan to your 1/3 of total flue area spec, and the outlet will be flush with the top of the hinged coupler. Astragal???, vaguely heard the word but applied to glazing bars on double glazed upvc windows! I guess you mean something inside the flue to cover the edge of the coupler to ease gas flow? there is a small step on one face, but the other three are flush. There is a slight size discrepancy between the old flue and the new one on one face. Can you sketch out what you mean or send a link? Once again thanks for the info. Every day is a school day!
            Phil
            East Yorkshire.
            • #36
              Just flat stock coming up from inside the lower element of the stack Phil providing a telescopic fit for the upper stack. Only needs to stick up about an inch to minimize air infiltration from the joint causing turbulence. Think of it as 2 joints of heat duct coming together.
              • #37
                Hi chaps, got the flue finished and put up this week, and also included my ride home over the Yorkshire wolds, like, subscribe, and enjoy!
                Phil
                East Yorkshire.
                https://youtu.be/qkP69FMS0W4
                • #38
                  Well here is an odd offering! have only been to the shop one day this week, as the weather has been very bad, and I am still a bit under it! Here is a job I did a few years ago on a Citroen 2cv, rebuilding the back end with new inner wings and boot floor. Beware of these cars! If you ever drive one, you will want one! They are so much fun, and dead easy to mend, but the downside is, they ROT! Not at all the car I would ever thought I would enjoy driving, just goes to show that performance isn't everything. Like comment subscribe, enjoy!
                  Phil
                  East Yorkshire
                  https://youtu.be/x6PVbn7_rho
                  • #39
                    Hi boys and girls, still not feeling quite right, but almost there! I did nothing this week, due to the storms and the wind howling round, so I have put together a slideshow of one of our late great engineering works, Doxford and Sons, of Sunderland, Marine engine builders. There is a link at the end to a silent colour amatuer film of the works in action. They built their last engine in 1980. Like, comment, subscribe, and as always, enjoy it!
                    Phil
                    Determined to get back to work next week cos i'm bored!
                    East Yorkshire
                    https://www.youtube.com/watch?v=_kWE95LEzQE
                    • #40
                      Hi Chaps, weather is still atrocious, bitter wind and horizontal sleet today, and I have stayed in the warm! here are some more of my projects, ongoing and finished, but we start out with the glory days of Dean Smith and Grace in Keighley, West Yorkshire, A factory I actually went to in the seventies when I got my first lathe, a DS&G 13Z. If you go to www.lathes.co.uk/dsg there is a factory tour there which is every bit as interesting as the Doxford one Hope you like it, and don't forget to comment and subscribe.
                      Phil
                      East Yorkshire
                      https://youtu.be/usA7r5qBmO0
                      • #41
                        Hi Chaps, the week was going so well, once it had started (Tuesday), weather has improved and I feel fit again, and it was all downhill fom there! When everything around you is going bad, you have to take the opportunity to "break on through to the other side" so it's head down, and puuuuuush!Like, laugh, subscribe, comment enjoy!
                        Phil,
                        East Yorkshire.
                        https://youtu.be/RFnsJj07X5k
                        • #42
                          Hi All, the welder part is on back order, and this week we decided, seing as the weather was good, to deal with some trees damaged in the recent winds, sort of commando gardening!. We have a 4 Acre field just across the village from the Workshop, and this week, and next week, if dry, will be a maintenance blitz, as it is next to the road, and fallen trees tend to interfere with traffic! please like, comment and subscribe!
                          Phil
                          Far East ( of Yorkshire)
                          YouTube
                          • #43
                            And Now, due to Keiths wife having a seroius heart condition (although you wouldn't think it when you see her work) and my wife having Asthma, we are self isolating from each other, so the fencing and completion of the field work will be at a later date! Normal workshop style stuff will contine as long as we are well, I can isolate myself there!
                            Phil
                            Spring like East Yorkshire
                            • #44
                              Hi people,
                              During last weeks work on the fallen trees, I discovered that my chainsaw, an antique Stihl 08S, would not start, here is the tale of me fixing it, and then fixing it again! Many thanks to "The Repair Specialist" whose youtube vids put right my mistake! Enjoy, subscribe, and above all, stay healthy!
                              Phil
                              unseasonably cold East Yorkshire! ( it was warm and sunny this morning)
                              https://youtu.be/m-KXpOnEg8k
                              • #45
                                Hi all,
                                Not done much due to the virus lockdown, I bet all the survivalists in the USA are rolling around their bunker floors, surrounded by food, laughing their heads off! I did get a day and a half in the workshop, made a cold frame for my daughters roof garden, she was pleased with the solid practical construction, but thought the aesthetics left a lot to be desired! Teenagers! There's no pleasing them! Like, comment, subscribe, enjoy! We live in "interesting" times.
                                Phil
                                East Yorkshire
                                https://youtu.be/mWXNaoyHm68
