DC motor info needed
  • MaxHeadRoom
    Are they normally an NC contact? I have seen thermal sensor wires recently on motors recently that I think are more likely a thermister based on the way the manuals say to read them.
    There are two types out there IIRC the Baldor is the NC Bimetal type.Open on overheat.
    In my experience the NC contact is the norm, just send an alarm to the controller or the actual relay to inhibit, Fanuc servo's use this method.
    A resistance check would confirm it.
    Max.
  • Bob La Londe
    Originally posted by MaxHeadRoom View Post
    The blue conductors are thermal sensor, they normally read short circuit continuity..
    They would normally open up a relay coil or enunciator etc when overheat occurs.
    Don't forget the Earth GND (green).
    Max.
  • Stu
    Thanks. Stu
  • MaxHeadRoom
    Max.
  • BCRider
    Given the warning about the internal switch and possible restart I suspect that the blue leads go to a "thermal warning" panel light. The blue leads might be a second independent set of contacts on the thermal cutout or they may feed motor power out to a light during a thermal cutoff event. Since it would be hard to test this without deliberately overheating the motor or finding some Baldor notes on the motor I'd say just cap them off and forget them.
  • RB211
    Put a wire nut on each one?
  • Stu
    started a topic DC motor info needed
    I have a Baldor 90v DC motor I'm going to use on a single lip cutter. The motor has 2 blue leads for thermal protection. I suspect I will not need thermal protection for this application. What do I do with the leads if I am not going to use them? Click image for larger version
